Indicators
I saw some trick looking pop-up indicators from Stainless Marine. They mount up top by the compass so you look through them while driving. Heres the link http://www.stainlessmarine.com/trim.html could be an option cause that panel is looking pretty full.
I am in the same postion as you Razor. It just depends on how you want to go about it. I was thinking about moving the circled trim gauge down and moving another gauge to where the ignition is and then moving the ignition to where it is in the bottom picture (Hope Dave M doesn't mind me using a pick of his dash). Then you will have an existing hole that you can cover up by placing indicators up buy the toggles. I think this will keep the holes in the dash to a minimum by just cutting out a new hole for the ignition down low. But I am also looking into the pod/style indicators that trick marine has. The only catch on your end razor is that you have 4 gauges in that stack where I only have three. I don't think the pod style up by the compass would be bad though.
Once you get the mech indicators you don't need the elect. trim gauge. I removed the elect trim gauge, then added a voltmeter, and dept finder. I moved the ign. and fuel gauge down.
I got thinking, after I replied, when I went looking at indicators, that I am not going to need that gauge. I am leaning towards not mounting the pod style as I am not sure where else I would mount my gps except for up on top of the dash.
I don't think the 5" indicator bezel will cover both holes. And I may be pushing it just removing the trim gauge. I may just leave the trim gauge and add the stainless marine indicators up top.
I like Dave Ms dash set up.
The first year I had my boat, I move my ignition switch and added a depth finder, voltmeter, and stereo; all with Dave's advise and model.
I had planned to remove the trim indicator and add the 3 mechanical indicators like Dave did, but I got used to not having indicators for the K-planes...
One other thing you fellows my want to add to the helm area, if your boat does not already have it, is the foot hole. It was something both Dave and I did after seeing JCs demo 24' Super, now owned by JMK406..
Patrick
Patrick
