Sportmaster questions, leave in fresh water? >
Old 12-11-2005 | 12:39 PM
IRONMAN's Avatar
Default Sportmaster questions, leave in fresh water?
What is the finish on the sportmaster lower? Can they be left in fresh water? will one bolt to a std. X upper? Thanks, Chris
IRONMAN is offline
Old 12-11-2005 | 01:05 PM
GOODT's Avatar
Default Re: Sportmaster questions, leave in fresh water?
wouldnt leave in water for the most part they are bare alum.
as for bolting to a stock x drive they will but why only as strong as the weakest link, in this case it would be the upper gears.....
Attached Thumbnails Sportmaster questions, leave in fresh water?-logo1111.jpg
GOODT is offline
Old 12-11-2005 | 01:48 PM
the gear change is done on the upper of a x and done in the lower of the sportmaster/xr.
audacity is offline
Old 12-11-2005 | 02:08 PM
marinetrans's Avatar
Use Merc's magnesium zincs in fresh wawa.
marinetrans is offline
Old 12-12-2005 | 03:37 PM
I'm not sure about the -2 sportmaster but if you are trying to bolt a standard length sportmaster lower to a XR upper then you will need longer studs than the normal XR lowers use. I have a set of sportmaster XR's and when I changed the lowers to -2 imco shorties the studs were too long.
Marginmn is offline
qshag
Fountain
34
08-13-2007 09:53 PM
G Man
16
06-28-2006 09:20 PM
jeff32
01-09-2006 07:21 AM
Joe
9
12-08-2005 05:43 AM
Stormrider
03-04-2005 09:29 PM
