not sure ..! Kevlar + Epoxy in stress areas >
Old 12-15-2005 | 06:03 PM
Default not sure ..! Kevlar + Epoxy in stress areas
question for u FRP Gurus out there... If Aramid Kevlar is laid on the inside of high stress areas ...at Keel and at Chines using epoxy....intsead of alternating combi mat with isopthalic ployester resin ...considering that the constuction of the boat is a Sandwich type using End Grain Balsa ..but at Chines and at Keel not having any core therefore having to add extra layers of solid glass in the above mentioned stress areas for added strength ... can anyone tell me if it is possible that one uses Kevlar combined with epoxy on the inside of the boat .... the other layers are of combi mat 18/10 using isopthalic resin...which are the outer and inner skins of the core where they practically meet as explained before as no core is present where i would like to increase layers ! ! ! due to the fact that Kevlar is 4.8oz in weight only nearly 4 times lighter ..layer to layer. ! ! ! hope i didnt mix u up .... ! ! ! hope u can answermy queastion....
CAN I DO IT YES OR NO ! ! !
zum.offshore.Malta is offline
zum.offshore.Malta
12-15-2005 08:04 PM
zum.offshore.Malta
Detailing, Painting, & Fiberglass
0
12-15-2005 05:57 PM
gdfatha
General Racing Discussion
7
06-28-2004 12:22 PM
Smitty
02-26-2004 10:28 PM
candyman35
05-08-2002 09:58 AM
