Upgraded spark arrestor/ECU kit .
I am also curious about the (vortex) kit that increases the fuel pressure, spark arrestor/ecu kit to go on a '98 502 MAG MPI.
Any one have any positive/negative feedback? Would the above be more effective with an exhaust manifold/header swap?
I didn't notice any gains with the flame arrestor. I then had the ECU reprogrammed and had the rev limiter bumped up and noticed maybe a mile an hour difference. My next step was to add headers and that did make a pretty big difference. At least 2 or 3 MPH. That still wasn't enough so I added a Vortech blower and gained 12 MPH. Now that I've gotten used to that I'm doing a stroker kit to a 540 with Canfield heads, roller rockers and a custom ground cam. I hope to see another 10+mph when I'm done. You're starting down that addictive road. I wish I would have bought a bigger blue motor in the beginning........
My advice on the arrestor is if you like the way it looks, then buy it but don't expect to spend a few hundred dollars and think your boat will run any faster. The headers will make a difference, plus they look nice too, but they are expensive. I'd say a 1000 dollars give or take equals a mile an hour.
Michigan Mad Man
Originally Posted by ginger
Has anybody installed one of these on there 502 EFI if so what what kind of performance gains did you get.
