Go Back  Offshoreonly.com > Race Talk > General Racing Discussion
recent OSS Super Cat Owner's Meeting >
Old 12-24-2005 | 10:29 AM
Pete B's Avatar
Charter Member#203
Veteran: Navy
Default recent OSS Super Cat Owner's Meeting
OSS Supercat Owners met to discuss rule changes for 2006 season: here is a link to the results:
http://www.offshoresuperseries.com/article.php?artID=55
Pete B is offline
Old 12-24-2005 | 10:38 AM
Sean H's Avatar
A to Z
Default Re: recent OSS Super Cat Owner's Meeting
i think the 850sci route would of been cool, but maybe next year....
Sean H is offline
Old 12-24-2005 | 11:52 AM
The motors are to hard to keep around the same HP, the pullys can be just a little off, or one blower can be more efficeint than another. I think durring testing they saw swings over 10% diff.
Like the rule where you get more points for running a motor more than one race.
CM
yahoo is offline
Old 12-25-2005 | 11:40 PM
so the min SC weight is lowered 500# to 9000#?
and will the SC engines be sealed in the boat? if not then they can be removed for testing. then be installed for the race.
audacity is offline
Old 12-26-2005 | 07:00 AM
fountain1fan's Avatar
he he he he
fountain1fan is offline
Old 12-26-2005 | 11:03 AM
Pete B's Avatar
Charter Member#203
Veteran: Navy
OSS Cat Owners Ballot Results
In a recent ballot, the OSS Cat Owners cast their votes on several issues concerning their class. Here are the official results :
ITEM 1
“OSS Cat weight minimum of 9000 pounds with 500 pounds of moveable ballast”
- PASSED
ITEM 2
“Water ballast tank fixed with pumping in and out of boat only”
- PASSED
ITEM 3
“1.61 mandatory gear ratio with current OSS Cat engine”
- PASSED
ITEM 4
“1.25 mandatory gear ratio with 850 Mercury SC”
- FAILED
ITEM 5
“Single source blower motor 850 HP”
- FAILED
ITEM 6
“2006 Season run either existing OSS Cat motor or 850 supercharged motor; Parity adjusted by PCM system; PCM system must be sealed and inspected by OSS tech inspectors before and after each race”
- FAILED
ITEM 7
“2007 all motors will be 850 super charged motors. All motors will be sealed and inspected by OSS tech inspectors before and after each race”
- FAILED
ITEM 8
“Nichols Offshore Racing shall be the only grandfathered rudder boat. No additional new or used rudder boats allowed”
- PASSED
ITEM 9
“Leave the existing 2005 motor rules in effect including 7600 rpm, with additional points awarded for running the engines multiple races similar to UIM rules.
For example, 5 points for one race, 5 points for second race, 5 points for third race and 7 points for fourth race. After fourth race maximum points have been achieved, and the system reverts back to the first race.”
- PASSED
ITEM 10
“Existing 2005 OSS Cat motors must be sealed.
The following items shall be sealed: Oil pan, heads, intakes and valve covers. (The only time the valve cover seal may be broken without penalty will be at a race site where valve or valve lash adjustment is performed in the presence of an OSS tech inspector)”
- PASSED
ITEM 11
“The maximum propeller blades is a 5 blade and maximum propeller pitch is 34.”
- PASSED
Pete B is offline
Old 12-26-2005 | 12:03 PM
jbs does that mean you are going to race supercat ?
yahoo is offline
Old 12-26-2005 | 09:00 PM
Why are they so against supercats with rudders? It seems that they would welcome anybody with a new boat rudder or not. The supercat number seems to be dropping. I'm sure Randy or Peter would love to built SC with rudders.
paintkahuna is offline
Old 12-26-2005 | 09:09 PM
peter is building SC's to his capacity right now. i like rules and the direction they are going.
would really like to know about the weight...
audacity is offline
Old 12-26-2005 | 10:02 PM
Sean H's Avatar
A to Z
i would guess the weight change was due to everybody adding so much weight to make the 9500, to make them basically meet a 8500 weight and then add 500 of ballast is how i read it instead of guys running 1k on the transom of some of those boats....
i am guessing the new skaters are way under the weight as are all the MTI's so basically they won't be adding as much ballast as they used to....
Sean H is offline
