Dry sump
Old 12-27-2005 | 10:03 PM
jeff32's Avatar
Default Dry sump
Tell me guys what Dry sump means. Is there dry sump engines? Or if it is only dry sump drives ? Thanks.
jeff32 is offline
Old 12-27-2005 | 10:10 PM
BBB725's Avatar
Default Re: Dry sump
In a wet sump drive the gears are turn in a bath of oil with the dry sump the oil is stored in a different reservoir and sprayed on the gears as they turn. Gears turn easier in air than oil less horse power loss.
BBB725 is offline
Old 12-27-2005 | 10:12 PM
NJSONIC's Avatar
Jeff32,
Yes there are dry sump engines as well as drives. On the engines there is normally an external oil tank to hold the oil allowing it to cool and to keep oil from splashing up against the crankshaft, which causes a loss of horsepower.The Porsche 911 is one car that has this. There is also less chance of loosing oil pressure during hard turns and acceleration.
NJSONIC is offline
Old 12-27-2005 | 10:17 PM
jeff32's Avatar
make sense! Thanks.
jeff32 is offline
Old 12-27-2005 | 11:11 PM
Ted G's Avatar
New Z06 has it also-500 hp from 427 c.i.
www.cbpba.com
Ted G is offline
Old 12-27-2005 | 11:12 PM
tomtbone1993's Avatar
very nice
tomtbone1993 is offline
Old 12-28-2005 | 10:59 AM
Is It Worth The Money To Dry Sump A Engine.
AeroSpeedMarine is offline
TeamPSI
6
02-01-2007 10:13 AM
gripit
10
07-15-2006 08:35 PM
JCPERF
02-22-2006 09:48 PM
offthefront
28
01-27-2006 06:25 AM
