Boat Battery
Being that it is winter and I have nothing better to do but research what batteries I will use to replace my old ones with I came across the AGM, or Absorbed Glass Mat Batteries. Has anyone used these? In an article I read they stated that AGM batteries are as good as the Gel style batteries if not better. They cost about the same, but the thing that caught my eye was they offer them in the same physical size as my existing deep cycle battery which means I don't have to replace my battery box like you have to if you go to a Gel style. Please voice opinions.
Thanks,
Mike
Thanks,
Mike
I too am looking into batteries. Mine need replaced in the spring. I am not sure which to go with. Any info is great.
I do have questions if I go with gel batteries. Can I use my current battery charger/inverter? I have the impression that gel batteries need a special kind of charger.
Thanks,
Bill
Thanks,
Bill
I run a pair of blue top optima's, 4 years old and seem to hold their charge very well. Cranks right up after 4 months storage and no charging. Run em in the race cars also. Don't think I will buy anything else for a while.
They will fit in most battery holders, but the ones designed for Optimas are a better fit.
http://www.offshoreonly.com/forums/s...d.php?t=112951
Check out this link, these are very lightweight if weight saving is important to you. If you go to the Odyssey website, they also offer nice boxes.
Yep, The ODYSSEY battery is the way to go if you want to keep the boat for a few years without problems in that area. Not cheap, but worth every penny!! --- Jer
I have Odessy's before, I have Optima's now, I don't think you can go wrong with either. The Optima blue tops are at Costco for about 150, nobody can touch that price, not even interstate dealers. Best thing about Costco is that they don't have a battery tester so you can get a refund every year and purchase new ones.
I've been using the spiral batterys from NAPA. Not sure who builds them. I've had a set in my CTD Dodge for 4 1/2 years, and the still crank as good as new. I have one in my 68 Charger, in the trunk, I used to replace that battery every year due to sitting all winter(on trickle charger) and the vibration from drag racing, that one is 3 years old and can sit for months and still fire up a 12.5:1 Hemi no problem. I have two in the boat and have had no trouble in two seasons, lots of air time, lots of sitting with the radio on, and never any trouble starting. I've even killed them dead, recharged them and they are fine. You should read the mfg specs on recharging though, be sure you have the correct type of charger. Most new battery chargers will have a switch for lead-acid/AGM. I'm sold on these batterys.
I use plain old Sears Diehards. For one reason is they happen to fit my battery box without the terminals touching the top metal part. They are $60, I replace them every 2 years. Never had a problem with them. My boat is subject to SEVERE poundings on a regular basis.
