need 2 tips on how to remove fuel tank >
Old 01-01-2006 | 10:54 AM
jeff32's Avatar
Default need 2 tips on how to remove fuel tank
Any body did that before? The tank is stuck in foam. beside the crow bar, what's the most efficient way to take the foam off ? And once it's done, tell me how or where to grab the tank to lift it ? you know it is in a real tight area, can't get a strap underneath the tank...
jeff32 is offline
Old 01-01-2006 | 11:01 AM
TomFTM's Avatar
Default Re: need 2 tips on how to remove fuel tank
You need to cut the foam around the tank . I have a hand saw that I bought at home depot that is rigid and has jagged teeth on it. Once you cut around the tank you need to get straps under one end of the tank . Then pull up with some kind of lifting device. (forklift, engine hoist , comealong, or whatever you got) . You must pull on one end at a time to break the suction on the bottom of the tank to the bottom of the boat. Good luck . That job is a pain in the ass. Tom.
TomFTM is offline
Old 01-01-2006 | 11:06 AM
GOODT's Avatar
HINT...carb cleaner or acetone will dissolve foam
GOODT is offline
Old 01-01-2006 | 11:23 AM
Hauling Trash's Avatar
bingo
2014 OPA-APBA National Champion Class 7 .Hauling Trash 725.
Hauling Trash is offline
Old 01-01-2006 | 01:31 PM
10x's Avatar
10x
10x
When I did mine, I cut all the way around the tank like was mentioned previously here. Then we took out the fuel sender and pickup tube at the rear of the tank, and put the hook from the engine lift into the opening. I had the engines out at the time, and when we started to lift, the whole boat was lifting off the trailer.
With the back of the boat about 2-3"s off of the trailer, my buddy and I started jumping, together, on the extension boxes. Finally after about 15-20 heavy jumps together, the 1st tank broke loose.
It's not an easy task. They're really stuck in there. Never thought about melting the foam.
Fountain powerboats rule "The Preacher"
Chicago Powerboat Club Director
[email protected]
www.chicagopowerboat.com
10x is offline
Old 01-02-2006 | 12:41 PM
RMPRam's Avatar
To remove the 2 tanks in my 38 Cigarette, after we cut the cockpit floor out, I borrowed an electric chain saw and used it to "saw" through the foam. It still wasn't enough to get at the foam that was under the tanks.
I also had my engines out at that time and when we had done all the above, a friend of mine and I jumped in the engine compt. with my chain hoist attached to a welded lifting strap/eye that was used on the original tanks for lifting in and out. I was lucky to have those eyes on both tanks at either end. If I didn't have those I would have cut 2 holes in the top of ea. tank and run the chain thru the holes as a lifting point. With tension on the chain hoist and the "jumping" they eventually let loose.
Plan ahead on where you will cut the floor and think about how you want to re-install it when the tanks are in and finished. A suggestion is to screw/glass "pads" that the floor can sit on around its perimeter. Then fill the cut with a paste mixture of epoxy/glassfiller and then use a combination of 6",4" and 2" mate to cover the crack.
If you want to give me a call I will be happy to help you any further.
Gary Kollofski
H: 763-473-8963 eves/weekends
RMPRam is offline
Old 01-02-2006 | 07:18 PM
jeff32's Avatar
Don't have hooks on the tank. Cutting hose in the tank is a good idea when you know the tank is already leaking, but I wish to use it again so I'm not comfortable cutting holes... after that I guess the tank is definitly no good, right?
jeff32 is offline
Old 01-02-2006 | 07:23 PM
BRUCE SEROFF's Avatar
couple gallons poured around tank. let saturate for a while
( couple hours) It will be much easier then.
BRUCE SEROFF is offline
Old 01-02-2006 | 07:58 PM
If you're pulling the tank on a boat more than 10 years old, you should buy a new tank.
You are doing one of the worst, most dreaded jobs that can be performed on a boat. These previous posts have some great advice.
Good Luck!
Edward R. Cozzi is offline
Old 01-02-2006 | 08:52 PM
R Addiction's Avatar
AT Cult Member #3
And there will be NO smoking anywhere near this boat for a while!!!
R Addiction is offline
scottmori
08-25-2008 02:18 PM
handfulz28
12-24-2006 07:16 AM
JGB
Cigarette
0
09-24-2004 09:21 AM
JROMY
2
07-23-2003 07:29 AM
Krumbsnatcher
9
07-16-2003 10:51 PM
