Alcohol 540 by Mesa Racing Engines
I haven't seen or heard many guys here with alcohol drag boats but here is one for a friend out of Texas for a drag boat out that way this is based on our MB650-MB850 platform such as Dart block billet oliver rods Crower crank and in this case the baddest flowing conventional heads in the country the CFE BMF and we mean BMF this is all toped off by a Ron's Flying toilet set up mechanical FI unit here are some pics of the machine work done on the block from parrallel decking to roller cam bearing machining and a close up of the pan were using on the unit. Hope you guys like and I'll have dyno numbers before the end of the week. Sincerely Laz
Once again Laz you have amazed me with your
choices in hardware!
Great work!
CFE heads are the best!
I was going to run his Bmf 385.
I decided to run his program on a couple sets of 18
degree Darts.
Will See
Gerry
Great work!
degree Darts.
Will See
Gerry
Originally Posted by Payton
Laz, nice work. What are all those fittings welded into the oil pan?
Originally Posted by thedonz
I am intimately familiar with the joys of installing the nuts onto the studs through those holes
great oil pan though.....good job Laz!
MESABALANCING
General Racing Discussion
11
02-22-2005 08:17 AM
