what temp thermostat are you running in you big n/a engines?
142 with Merc. circ. pump on my 548. Warms to operating temp. in less than 5 min. after cold start and never exceeds 145. I had trouble getting up to operating water temp. and never could get the oil up to 200 causing some milkshake under the valve covers with thermostat removed. And NO; I had no reversion or leakage issues; Just wasn't getting the oil warm enough to vaporize ever present moisture. --- Jer
I am running a 160 deg thermostat with two 1/8 holes drilled in it. I also have a Eddie marine bypass crossover eliminating the water circulator. I run a solid 150 on the gage until I come off plane, the gage goes up to about 180 for a few seconds and then goes back down to 150.
gripit
01-07-2006 09:08 AM
