what size weep holes in a thermostat for an eng with crossover set up >
Old 01-06-2006 | 08:09 AM
ratman's Avatar
Default what size weep holes in a thermostat for an eng with crossover set up
i saw a thread a while back where guys with a thermostat were drilling some holes in the thermostat to cool the exhaust even while the thermostat was closed. what size and how many holes are you drilling in it. thx ratman
ratman is offline
Old 01-06-2006 | 08:49 AM
Nordicflame's Avatar
Default Re: what size weep holes in a thermostat for an eng with crossover set up
The crossover will do it's job and keep the exhaust cool but a few small 1/8 holes will help keep any steam out.
Dave
Nordicflame is offline
Old 01-06-2006 | 09:49 AM
PatriYacht's Avatar
Always use a crossover with a bypass hose. The holes help to even out the temp fluctuations that occur. I use 3-3/16 holes.
PatriYacht is offline
Old 01-06-2006 | 12:21 PM
kaama82's Avatar
start with one hole, work your way up until the results are best for you. just my .02 cents
kaama82 is offline
Old 01-06-2006 | 12:27 PM
GOODT's Avatar
agree with kaama start with one 3/16th and add from there real hard to refill the hole after the fact
GOODT is offline
Old 01-06-2006 | 01:16 PM
All good stuff...These additional holes will also help keep some of the cold water coming from the crossover off of the top of the thermostat. This can cause the thermostat to fluctuate.
They also will aid " a little" with excess water pressure when the thermo is closed but that's a whole different topic
Dave
Old 01-07-2006 | 09:17 AM
Payton's Avatar
Charter Member #927
I needed 3 1/4" holes in order to keep my risers cool until the thermostat opened. But, I am running a Gil, cam driven, water pump.
Payton is offline
Old 01-07-2006 | 09:38 AM
RLW
Is this because you are not using a "bypass style" crossover?
RLW is offline
littledcsrodshop
Wanted
3
06-19-2008 08:56 AM
powercat
Wanted
0
01-17-2008 08:15 PM
mwillis
2
04-09-2006 12:00 PM
Speed H2O
6
12-19-2002 12:45 PM
SLINGSHOT
04-23-2002 10:47 PM
