35 2000 twin step
Does anyone know in the ist year model change with the 35 twin step, did they do any experimenting with the x dimensions or locations of steps or any changes in 01 to correct 00 problems if any. I know in 95 1st year of single step they moved step around untill they found sweet spot
thk Joe
thk Joe
2000 was the first year of the twin step and fountain had some problems with the X dimension and the ability for the boat to come out of the hole. In 2001 they fixed the X dimension and no problems. I own a 2001 35' Fountain and do not have any problem with the new set up. I would not buy a 2000 if I were looking. Not much difference in price to set up 1 year.
Originally Posted by gferdon
Hey Mike,
Do you happen to have any info on a 2000 35 Classic (single step) with the HP500's? Just curious on top end and how they got up on plane...thanks.
G-
G-
Thanks guy's I would have thought that the 00 would of been a higher X dimension because I read somewhere that some of the oo had a problem coming on plane and some boats where sent back and fountain installed a spacer to lower the drive, I also thought that 01 went to merc., props because of merc'c involvment with fountain. I am know worried is buying a 00 because you can always lower your drives with spacers but to raise alot more trouble and expense.So from what I am reading the merc prop likes a higher x than a hydro. If this is the case an oo would be okay with a hydro with the lower x dimensuion?
