Need a bezel for Kiekiefer (sp?)
Looking for a trim bezel for a 4 lever setup. I've talked to all te normal go-to's and they don't have. Who does?
Originally Posted by US1 Fountain
What is the base measuremant you have?
The Livorsi throttles are exactly like the EMI, the only difference is the name on them. They are both made by the same company in Canada so the Livorsi bezel isn't going to help you either. Try the bezel for the Gaffrig shifters. They are shaped more like the Zero effort Merc throttles.
Here's a link to Tp, he sells the Gaffrig stuff and I sure he can get you the bezel for thier shifters.
http://www.tpmarine.com/index.asp?Pa...ROD&ProdID=723
is the part you are looking for listed in this diagram?
http://www.mercruiserparts.com/Show_...+%284+Lever%29
Originally Posted by JasonSmith
It is bigger than the Livorsi shifters. I ordered one from Eddie Marine, it was too small. I need to clarify what I am looking for. I want a trim ring for around the base of the shifters/throttles.
Yes, I know what you are wanting, but was curous how much larger from the Gaffrig/Livorsi,EMI's.
Not much to it if you need to make one then have it P/C'ed
