What does it take to run your props inward?? >
Old 01-09-2006 | 06:41 PM
thisistank's Avatar
Default What does it take to run your props inward??
On 3a's?? I would like to try it and see what happens. I know on the Bravo's you can just run it in reverse but have been told that's a no go on 3a's. What needs to be done to try it?
thisistank is offline
Old 01-09-2006 | 06:48 PM
OldSchool's Avatar
Default Re: What does it take to run your props inward??
Not sure about #3's, but with #6's you have to swap the drives. I'm swapping mine to spin out.....tired of looking like a 12 year old while parking! It's a bear to get around in the docks with them spinning in, but in all fairness, I didn't get enough seat time to get used to it.
OldSchool is offline
Old 01-09-2006 | 06:58 PM
you need to swap the drives
thedonz is offline
Old 01-09-2006 | 07:51 PM
Smile Re: What does it take to run your props inward??
Yup.
Edward R. Cozzi is offline
Old 01-09-2006 | 08:01 PM
on 5's change sides on lower halfs of drives , tried turning in not as good as out. and yes hard at docks.
Scooter is offline
Old 01-09-2006 | 08:16 PM
Underdog88's Avatar
Veteran: Navy
Mine turn in on bravos now. Just bought the boat and havn't got it wet yet. What are the advantages to this? I hear the disadvantages. What does it take to swap back if needed?
Underdog88 is offline
Old 01-09-2006 | 08:17 PM
OldSchool's Avatar
It's different on every boat...but usually 2-4 mph's faster spinning in.
Old 01-09-2006 | 08:21 PM
Underdog88's Avatar
Veteran: Navy
hmmmm.... may be worth looking bad at the dock for that
Old 01-09-2006 | 09:15 PM
HotPursuit's Avatar
Drain oil and change the lowers.1 gasket and no steering or trim to R&R. Turning in more bow lift. Docking will get a little
funner. I ran crash boxes turning in on a cat for 4 years.I'm
still alive.
HotPursuit is offline
Old 01-10-2006 | 06:40 AM
ratman's Avatar
so it was dumb luck?
ratman is offline
