alluminum vs. cast iron heads >
Old 01-10-2006 | 08:55 AM
Default alluminum vs. cast iron heads
I have two 540 ci BB, I beam rods, 7.5 comp, cast iron heads, econel exhaust valves ss intake, crane roller rocker arms 1.7, crane hydraulic roller cams,
I have major damage on one of the pistons that will need to be honed out.
What are the benefits to going with alum heads and would you do the same to the other good engine??????
What other changes would you do....
Dyno at 800hp a piece
berman58 is offline
Old 01-10-2006 | 09:19 AM
Tantrum's Avatar
Default Re: alluminum vs. cast iron heads
If you have closed cooling or only run fresh water aluminum could be the way to go. Salt water and aluminum heads are a problem.
Tantrum is offline
Old 01-10-2006 | 09:23 AM
Panther's Avatar
Frank's Marine Service
7.5 Comp. Ratio, is it supercharged?
Panther is offline
Old 01-10-2006 | 10:12 AM
671 BDS Blowers
berman58 is offline
Old 01-10-2006 | 10:15 AM
ONLY run fresh water
berman58 is offline
Old 01-10-2006 | 03:27 PM
racinfever's Avatar
Originally Posted by blastersbro
that combo sounds like junk who built it?
SUGAR COATING is extra!
racinfever is offline
Old 01-10-2006 | 03:53 PM
Blaster be more specific...
It dosen't mater who built it I'm Just asking for opinions.
What sounds like junk...
berman58 is offline
Old 01-10-2006 | 04:03 PM
KNOT-RIGHT's Avatar
alluminum heads are better then cast iron
easy to repair and coating is available for salt water
use.
Your combo is Fine!
Here are some great heads.
AFR
Canrnfield
Edelbrock
Dart
Brodix
Any of these would do you fine
Gerry
KNOT-RIGHT is offline
Old 01-10-2006 | 04:21 PM
Thank you Cave.
As a new member its discouraging when someone like blaster says what he does. Although I went back through his posts and he pretty much only posts derogatory things. Sounds like he doesn't have a clue and says he's a phamaceuticals sales rep. so his owning of big power boats I'm sure is limited....
berman58 is offline
Old 01-10-2006 | 07:08 PM
Rookie's Avatar
it does get discouraging to post on the general forum page. You might want to move this to the tech section, you will get more responses and less s#it, and they are generally friendlier over there. I read the general forum all the time, but never post cause of this behavior.
sorry it had to happen.
Rookie is offline
