22.5 wheels f-350
Registered User
Any body have the front end leveling kit with the 22.5 wheels if so what brand kit ,where you bought wheel and tire package.The best price I have found for wheel and tire package is from USA Dually.Also all the pros and cons with this set up especially when towing.
I put them on a 2003 F350 dually. I can't remember the name brand of the lift kit but it was 2 inches. I bought the wheels from chromewheel.com and I think I paid about 4k for wheels and tires. I only towed a fishing boat (31 Jupiter) with the truck but towing did suffer from the stock set up. It sure did look good though!
uhm adapters! would be the first con. if you want a true bolt on 22.5 look at the brentz more money but direct fit no adapters hub and lug centric. for a leveling kit they are all about the same. For the fords you have a couple of options like full spring replacement to a hanger kit. either of these will achieve what you want todo. with the bigger wheel setup I would also beef up the steering components a little bit as well.
