Dry sump vs. Wet sump #6s
Old 01-11-2006 | 06:11 PM
JCPERF's Avatar
Default Dry sump vs. Wet sump #6s
How much difference in speed are the 2 drives?What is the sweptback skeg worth over the wet sump skeg?I have heard alot of #s but has anyone backed to back the drives?
JCPERF is offline
Old 01-11-2006 | 06:15 PM
OldSchool's Avatar
Default Re: Dry sump vs. Wet sump #6s
You better not come up with a pair to sell!!!!!
OldSchool is offline
Old 01-11-2006 | 06:26 PM
lightspeed's Avatar
Dry Sump Drives Are The Way To Go ///Uses Less HP Than The Wet Sump///// No If Ands Or Butts///go with a dry sump
lightspeed is offline
JCPERF's Avatar
Originally Posted by blastersbro
dont worry you will have one to test back to back with soon enough.
Yeah yours
JCPERF is offline
Old 01-11-2006 | 06:29 PM
JCPERF's Avatar
I know they are better but how much better?
JCPERF is offline
Old 01-11-2006 | 07:02 PM
stecz20's Avatar
i thought you knew everything...
stecz20 is offline
Old 01-11-2006 | 07:03 PM
JCPERF's Avatar
I do ............almost
JCPERF is offline
Old 01-11-2006 | 07:20 PM
The Menace's Avatar
From my understanding at least 5 mph. However, it depends on your prop set up as well. If you are already at the rev limiters you will see zip improvement.
The Menace is offline
Old 01-11-2006 | 07:32 PM
offshoredrillin's Avatar
I read somewhere that the swept skeg really only helps at high speeds, 95-100 +.... And on lake champlain at that speed you were hardly in the water and Byrd was holding on for dear life...
offshoredrillin is offline
Old 01-11-2006 | 07:43 PM
stecz20's Avatar
i better ask z all my important questions......
stecz20 is offline
