Side Tilt Trailer for 40'+ cat info needed >
Old 01-11-2006 | 11:47 PM
LubeJobs42's Avatar
Default Side Tilt Trailer for 40'+ cat info needed
Anyone know of a side tilt trailer for sale for a big cat? Any idea where to look. Used prefered!!$$
LubeJobs42 is offline
Old 01-12-2006 | 01:45 AM
Sean H's Avatar
A to Z
Default Re: Side Tilt Trailer for 40'+ cat info needed
used are probably pretty scarce, myco or american trailer are probably your only two choices... 75k or so new..
Sean H is offline
Old 01-12-2006 | 08:50 PM
LubeJobs42's Avatar
If a boat has a 12' beam do you need wide load permits?
Old 01-12-2006 | 08:52 PM
Sean H's Avatar
A to Z
anything over 8'6" you do.... anything past 10'0" will attract alot of attention...... 12' is a circus going down the road....
Sean H is offline
Old 01-12-2006 | 09:25 PM
I wish I had those problems !!!!!!!! YEAHHHH BABYYYYYYY
Donzi Corleone is offline
Old 01-12-2006 | 09:57 PM
Brad Zastrow's Avatar
I spoke to Myco about a tilt trailer. They are big dollars and used will be almost impossible to find. They are very heavy trailers and you will need a large truck to pull it. A one ton dually will be a problem, not so much for the weight but now you have a big sail up in air. Wind gusts can really push a boat around loaded on it's side according to Myco. You will need a big truck/ tractor. I gave up on the idea.
Brad Zastrow is offline
Old 01-12-2006 | 09:59 PM
racesdad's Avatar
gino call bravo shop... dean has one that was under our old 48 cougar
old erics reality boat
racesdad is offline
keirmon
17
06-26-2007 03:50 PM
J.B. Marshall
11
06-07-2006 06:50 PM
J.B. Marshall
04-09-2006 09:24 PM
seltzer
03-06-2006 07:51 PM
NASTY HABIT
10-09-2003 08:03 AM
