Formula door squeaks??? (where's Magicfloat) >
Old 01-14-2006 | 09:27 PM
t500hps's Avatar
21 and 42 footers
Default Formula door squeaks??? (where's Magicfloat)
The cabin door on our 312 squeaks while underway. Seems a little chop makes something rattle and I can't duplicate it while at home on the trailer. I believe one of the plastic "runners" that are attached to the bottom of the door is missing. The door also seems to have some up and down play at the rear of the door suggesting the problem is here. Could that be it and how in the world do you remove the door to replace that runner???
Russ C.
t500hps is offline
Old 01-17-2006 | 09:53 AM
t500hps's Avatar
21 and 42 footers
Default Re: Formula door squeaks??? (where's Magicfloat)
Ttt
t500hps is offline
Old 01-17-2006 | 11:38 AM
Charter Member #415
Direct from Formula TAG "If a runner is missing it could cause a squeak.You don't have to remove the door to replace them,you just need 2 people to do it. They are held on with 10/24 bolts and nylock nuts.lower sliders $46 each. Upper $15 each,there are 2 upper and 2 lower."
Magicfloat is offline
Old 01-17-2006 | 11:57 AM
t500hps's Avatar
21 and 42 footers
Looks like I'll be calling you and placing an order......
Thanks Robert,
Russ C.
t500hps is offline
RedDog382
06-08-2008 09:02 AM
Boomer 880
03-02-2007 03:31 PM
BigDaddy96
06-01-2005 09:36 AM
Slick02
05-13-2005 07:51 AM
