Quick Wiring Question On Brake Controller
04 PSD and I,m installing the Draw-tite Activator II, In the instructions it says to connect the the power wire directly to the battery with a 30A breaker, and the ground as well. Should I do this or is there an easier way? I'm figuring that this might be the only way to do it and not mess up the electrical system. The blue wire and the red wire are going to just hook up to the supplied factory harness.
I've got to get this right as I will be travelling up and down the Monteagle Mountain just outside Chattanooga right out of the box with my new rig. All of you know that have seen it that it is a monster! Not one to go down with 10K and no trailer brakes.
Thanks, Eric
Thanks, Eric
Directly to the battery so you are not pulling power from another circut, overloading it, then blowing a fuse. Then you will have no brakes along with whatever you tied into. 30 amp is a pretty good size circut. They don't want people tieing into an existing 10 amp and thinking they are good to go.
Install the power wire as instructed. The ground can be fastened to any metal part. Don't forget to check the system every time you start out. Also, check the fourway flashers do not activate the brakes. If they do you will need to install a pluse preventer in the system. Not all app will do this but if you should happen to use the 4-ways it will pluse the brakes as well.
My wiring harness appears to have all but a power lead to the battery. It has a ground, but the instructions say if the power goes right to the battery then to ground at the battery as well. Muffman and Birddog my manual says nothing about the controller. The supplied factory harness has a red, blue, white and a much smaller guage green.
You already have a prewired circuit in your truck that is set up for this. Get the harness out of your glove box, wire it to your controller correctly, plug it in and start using it.
The prewired circuit is fused correctly for this application. Don't let everyone make it more complicated than it already is.
I will be more than happy to call you and talk you through the details of the installation. Just by chance I installed about 20 of them this last week alone.
Buck
Buck
White is ground. Should go to white on controller.
Blue is the brake wire going to trailer brakes. Should go to blue wire on controller.
Green is the signal wire that will more than likely go to a red wire on your brake controller.
Plug it in and job done.
Buck
