engine submerged >
engine submerged
engine submerged
Old 01-17-2006 | 05:31 PM
tuffenuff355's Avatar
Default engine submerged
a friend of mine recently bought a boat that sank with twin 454[365]mags, Does anyone have an idea what he should do?thank you for any advise.
tuffenuff355 is offline
Old 01-17-2006 | 05:40 PM
Catagory5's Avatar
Default Re: engine submerged
Where the motors pickled as soon as they came out of the water?
Catagory5 is offline
Old 01-17-2006 | 05:48 PM
375stinger's Avatar
we pickled our 454 mags in the 375 12 years ago when it submerged in salt, and they ran for another 9 years....
375stinger is offline
Old 01-17-2006 | 05:50 PM
as far as i know he as changed the oil a couple of times and says its still milky. i told him i'd get some advise from you guys
Old 01-17-2006 | 06:49 PM
Depending on how they were flushed it could come up milky for three or more oil changes. The BIG questions; Was it a salt water dunking, and how many hours (yes, "hours", not days) before they were serviced and fired?? If the answers are "salt" and "days"... Just fold, leave the cards on the table, and walk away. --- Jer
jpclear is offline
Old 01-17-2006 | 07:11 PM
ratman's Avatar
or if your a gambler go all in. if you can steal the boat and you should be able to if it was submerged, you can get the parts boiled in a good hot tank then media blasted and reuse most or the hard parts, cranks, rods, heads, blocks, etc. the other stuff ya have to buy new for a rebuild anyway. just my .02
ratman is offline
Old 01-17-2006 | 07:35 PM
monstaaa's Avatar
if its e.f.i throw all the electronics out. there junk. if not now they will be. if its carb like he said ^
monstaaa is offline
Old 01-17-2006 | 07:56 PM
375stinger's Avatar
ours was salt, or however much salt is behind our old house on big pass on siesta key, for a few days it was...
Old 01-17-2006 | 08:02 PM
GOODT's Avatar
big question does it crank and as asked above was it pickled if the answer is yes as stated above oil will be milky a couple more times after that you will need to run it and " steam" off the water because no matter how many times you change it there will still be a little water that will have to be steamed off.....or just rebuild and any electronics that had any power to them are trash...
GOODT is offline
Old 01-17-2006 | 08:30 PM
wantsa311's Avatar
Does it make a difference if the engines were running when the boat sank (it was stuffed) as compared to, say, sank when it was docked?
wantsa311 is offline
