Bluewater trim indicator
Old 01-19-2006 | 03:37 PM
Default Bluewater trim indicator
I have a Bluewater Trim indicator and need to change the inside from black to white.oes anybody know where I can buy just the indicator card.
Mark
fishead is offline
Old 01-19-2006 | 03:40 PM
Default Re: Bluewater trim indicator
This is it
fishead is offline
Old 01-19-2006 | 05:10 PM
Doug's Avatar
(aka) Pure Adrenaline
Mine was Bluewater in my Mistress and black. I went to the local shop that does engraving and makes trophies. I did it in white and when they cut the numbers they were red to match my gages. The material you have might be a little thicker than what they use but they should be able to order it. Give them the old one and they can match it in any color. I also went to the local glass shop to replace the clear plexiglas. If you need any help let me know. Doug
Doug is offline
Old 01-19-2006 | 09:45 PM
rbtnt's Avatar
I worked with Bluewater on custom indicators. Here a link to their site.
http://www.bluewater-1.com/index.html
www.mtboats.com - Pages of boat related links
rbtnt is offline
Old 01-20-2006 | 04:05 PM
Called Bluewater and they wanted 90 dollars just for the insert.Hey Doug who did yours and what did it cost I may send it up there.
Mark
fishead is offline
Old 01-20-2006 | 04:33 PM
Doug's Avatar
The store is called Two Brother Engraving, Marion Indiana. It's been about 3 years so I don't remember the price. I'm sure not over $20. I think the plexiglas might have been $5. I drive past it everyday, Monday I will stop in and show them my old one and ask how much. Mine was 4 slot and you only need 2. You wanted white, what color do you want the numbers ? probably black ? Be glad to help out.
When you take that apart be careful because there are tiny springs behind the position indicators. Very simple to change over.
Doug is offline
Old 01-20-2006 | 06:24 PM
If you could find out I would appreciate it and I can call them and send up the old one.My bezels are red so I would probably go with red.Mine came apart real easy.I did not have to take it totally apart.Mine is only 2 slots and I didnt even have to remove the cables.Probably a difference between the two and four.My cell is 678-522-4873.
Mark
fishead is offline
Old 01-20-2006 | 08:00 PM
Harper220's Avatar
I don't know if it's their website, but those indicators look dated.
Harper220 is offline
Old 01-23-2006 | 04:28 PM
Doug's Avatar
Ha Mark, I checked on that today and she said she can do it no problem. I took my old one in so she would remember it. Not sure if any material was left from doing mine but she will check when yours comes in to make sure it's the same thickness and can call you with a price. Here is the info, if you want me to check on it when it's finished I can or if you have any problems let me know. Doug 765-506-0672
Two Brothers Engraving
326 S. Washington St.
Marion, Indiana 46952
Att. Lynn Allen
1-866-896-2767
Doug is offline
Old 01-24-2006 | 12:40 AM
Doug thanks for the help.I was driving around town were I live and saw the local Trophy shop and I walked in and they can do it for 30 bucks.Sorry to put you through the trouble and thanks again.Mark
fishead is offline
