Need HP500 Intake manifold
I have a couple of Hp manifolds 1996 - the salt water has eaten a lot of the water crossover - but they do not leak - for fresh water they should be fine and they are free - you pay shipping - ( these did not have the bronze inserts)
AKA NoMoBoatin
Originally Posted by docmanrich37
James do you have any 34 or 36 props i can use for testing in a couple weeks.whipples are going on next week.If you need a place to hang your #6's i would be glad to help you out.
I' ve got a Dart large oval, same as the HP500.
No brass insert and it's painted black.
$50 + shipping.
I also have a new Rectangular port off of a 502HO.
$50 + shipping.
$50 + shipping.
$50 + shipping.
Patrick
Patrick
if you order this from an automotive supplier, i.e. jegs or summit. make sure to order part number 41114000ch this way it will fit the chevy heads.
i just bought a set from jegs new for 399.00 per the merc part number for mine is 848554t 2 dealer cost is $892.65 retail is $1487.75 just paint it blue and you saved about $500.00 per the only differance is that merc adds a pcv valve to their model, i do not know the reason for this
No Bravo 34 or 36's - have hydro 5 blade & hering six blade 30-31 -32 and a set of five blade merc's 32 that you can test - Merc Props are in VA - the others are in Sarasota - you pay shipping -
AKA NoMoBoatin
