gimbal bearings >
gimbal bearings
gimbal bearings
Old 01-27-2006 | 07:35 PM
nordic95's Avatar
Default gimbal bearings
Which way should these bearings go into the transom?Cut out towards motors or drives?And the books shows to super glue the tolerance ring to the bearing,is that right?
Thanks Nordic
nordic95 is offline
Old 01-27-2006 | 07:50 PM
marinetrans's Avatar
Default Re: gimbal bearings
Merc puts them in w/ notches towards inside of boat.Either way is fine unless you see a red dot on bearing carrier, then it faces out towards drive.
marinetrans is offline
Old 01-27-2006 | 07:51 PM
nordic95's Avatar
The ones that came out had red dots,these do not.So the notches go towards the motor?
Nordic95
nordic95 is offline
Old 01-27-2006 | 08:05 PM
Gots to get the ones w/ red dots,or else you'll put some hurt on your drive/gimbal.
Old 01-27-2006 | 08:08 PM
Don't forget to line up the grease hole.
TomR is offline
Old 01-27-2006 | 08:36 PM
GOODT's Avatar
you need to line up the crush ring and the oil holes.....
heres the break down of the gimbel ring the fiber washers are#3
GOODT is offline
MDGperformance
Drives and Lower Units
10
12-24-2007 07:59 AM
SSComp
2
05-12-2003 10:48 AM
boot
07-16-2002 12:15 AM
josh
4
06-13-2002 11:31 AM
josh
0
06-12-2002 02:10 PM
