purple engine enamal???? >
Old 02-02-2006 | 10:33 AM
Default purple engine enamal????
out of a can....deep purple.....not "lavender"......cant find any......anyone know where I can get some?????......does it even exist???
pullmytrigger is offline
Old 02-04-2006 | 04:04 PM
Crazyhorse's Avatar
Default Re: purple engine enamal????
Your local automotive paint supplier/wholesaler can mix it for you and probably put it in a spraycan or sell you the self-spray kit cheap.
Crazyhorse is offline
Old 02-04-2006 | 07:18 PM
Don't know how far you wish to take the paint process PMT, but I will share with you the part numbers to my two step Deep Candy Purple color. All PPG product.
Base color: Deltron 2000 #DBC59840 ultraviolet purple
Hardner: DCX61
Reducer: DT870
Clear color: Concept DCU2042
A little longer process, but sprayed with a High Volume-Low Pressure paint system with great results. And I am in no way an experienced painter.
ROTAX454 is offline
Old 02-06-2006 | 05:31 AM
Strip Poker 388's Avatar
Rob
Hardner: DCX61
Reducer: DT870
I like that color
Strip Poker 388 is offline
Old 02-06-2006 | 08:47 AM
Originally Posted by Strip Poker 388
I like that color
Thank you. I was trying to match the powder coat color that I had the upper drives done in. Spot on match!!!!!! The two step (color-clear) process gave me that deep color look. Glad I took the paint supply guy's suggestion. In the Detroit area, Painters Supply, the best!!!!
ROTAX454 is offline
Old 02-06-2006 | 09:02 AM
it appears blue in the pic......but its purple???
I was hoping to get something in a can as I have no air or anything.....and to have someone do the two motors it will cost like 4 or 500 bucks....I was hoping to do it for like $15......doug
Old 02-06-2006 | 09:11 AM
apparently Dupli-colour has one called "Plum Purple" p/n DE1640 although I cant find it up here.....some places carry Dupli-Colour but dont list that p/n.........the big players in this area are VHT and PlatiCote.....I spoke to Dupli C direct on the phone and they told me about it.......I may see if I can get them to ship it direct from Florida
Old 02-10-2006 | 10:47 AM
fund razor's Avatar
You might wanna check with OSO member 32caliber.
He is one of the world's leading experts on purple.
fund razor is offline
Old 02-10-2006 | 05:32 PM
Donman's Avatar
Duplicolor does indeed offer a purple engine enamel. To me, it is a little dark, almost maroon. I can get it at the local parts stores.
Donman is offline
Old 02-11-2006 | 03:10 PM
masi242's Avatar
Con you still use these products if you keep your boat in the water? I usually use mercury paint but would like to try something diffrent maybe a silver lower?
Any thoughts would be great.
masi242 is offline
