Need to borrow a set of Bravo 1 28's
Matt can you run some calcs to help me figure out were I will be as far as props and speed.
6600 LB boat
24 Degree V w/ delta pad/ no steps
557s, 6000rpm, 660HP/722Ft.Lbs.
Arneson Surface Drives 1.36 ?? (I'm still waiting on these)
Here is where I was Before rebuilds
502s, 5400rpm, 500hp/565 Ft.lbs
Bravo 1s w/ 1.5
24 Hydros
76mph
Thankyou
Jud
6600 LB boat
Bravo 1s w/ 1.5
24 Hydros
76mph
Thankyou
Jud
We also have a complete line of Bravo 1 propellers for testing should need them.
JShoup, you will slill be in the mid 20's for pitch in order to turn the higher rpm with the higher gear ratio.
[email protected]
[email protected]
rchevelle71
06-22-2008 02:22 AM
DollaBill
06-25-2007 11:52 AM
