950 procharger carb >
950 procharger carb
950 procharger carb
Old 02-03-2006 | 08:58 PM
375stinger's Avatar
Default 950 procharger carb
we are adding prochargers to our 555s and will be needing to purchase new carbs. we want 850-950cfm and need to have a 4150 style carb to fit in the m3 box. what do people recommend, holley or bg or any others? i cant find a marine 950 anywhere.....thanks
375stinger is offline
Old 02-03-2006 | 08:59 PM
375stinger's Avatar
Default Re: 950 procharger carb
o btw...8pounds, will be about 960hp each
Old 02-04-2006 | 05:33 AM
Stinger, Just south of you in Bowling Green, we have a company called Quick Fuel Technologies. It is just down the street from Holley. Tyler Crockett uses them all the time. They put together some carbs for me for my blower motors that worked flawlessly. They test and calibate all their carbs on a motor. They are small and will make you happy. They are also cheaper that anything out there. Having said this, from 2nd hand knowledge you might need to contact Dean Nickerson. Carb set up in the box is a different animal, that someone with a lot of experience needs to handle. The carbs from him will be expensive, but most likely right, which means you might save a lot of time and money before all is said and done!
Eric
SkiDoc is offline
Old 02-04-2006 | 07:14 AM
AKA NoMoBoatin
375 If you havn't bought the prochargers yet i have new m4 for sale.bought it and never had it installed.single carb box polished plumbing.
docmanrich37 is offline
Old 02-04-2006 | 07:49 PM
375stinger's Avatar
docman: we already orderd the m3s, but thanks
thanks for responses, anyone else have any input?
Old 02-04-2006 | 08:01 PM
Talk to Nickerson (215) 781-1370. His personal boat engine has our Rtech Supercooler (intercooler and carb box in one) and a Vortech V-4 compressor. It's a 498 with GM iron heads and a solid roller cam, making 1013 HP @ 6100 RPM. Dean knows what you need.
tomcat is offline
Old 02-04-2006 | 08:41 PM
375stinger's Avatar
thanks tomcat, we looked at the rtech system when getting the m3, but had to put our intercoolers in custom locations because the hatch was too short, and wanted to keep the sunpad. does anyone have a website for nickerson? thanks
Old 02-04-2006 | 09:02 PM
Do whatever you have to do to get blown, that's what I say.
Try www.nickersonperformance.com
Just to clarify for other readers, the Rtech box is the same height as the Procharger carb box but it carries forward farther so you have to check the hatch clearance near the front of the engine, not just above the carb.
tomcat is offline
Old 02-04-2006 | 09:06 PM
375stinger's Avatar
yeah, our problem was not just height, but it sticking forward...thanks for the link
Old 02-06-2006 | 06:40 PM
The carb in the box setup never worked right.
Back4More is offline
