Ingenious Marine software >
Old 02-06-2006 | 02:39 PM
JasonSmith's Avatar
Default Ingenious Marine software
http://www.azspeed-marine.com/inmaso.html
Anyone have it?
JasonSmith is offline
Old 02-06-2006 | 05:29 PM
Default Re: Ingenious Marine software
looks cool anyone got this????
powerquest 380 is offline
Old 02-06-2006 | 06:13 PM
Dave M's Avatar
Veteran: Navy
I have this....
http://216.230.203.183/acro/DiacomMarine.pdf
It is awesome, it looks similar to what you are looking at. It doesn't allow for tuning and calibration though.
Dave M is offline
Old 02-06-2006 | 06:22 PM
JasonSmith's Avatar
I want it for tuning & calibration. I guess it works on more than one ECM, hints I could hook up my friends!
Old 02-07-2006 | 10:42 AM
Thumbs up Re: Ingenious Marine software
We have and use Jim's Ingenious software. It works very well, is very user friendly and fairly simple to use. Jim has updates coming to make it even easier to tune. We do a lot of work on the dyno and our new 725HP 600 inch N/A 496 Raylar motor is equipped with the MEFI4b tuned with Jim's software.
Ray @ Raylar
Raylar is offline
Old 02-07-2006 | 06:38 PM
paradigm shift's Avatar
725HP 600 inch N/A 496 you are confusing me? 496 based block made to 600 ci. What kind of piston wear are you getting or have you had enough run time. Long pulls not little 30 seconds blasts they do not count.
You have some great stuff I just wish I has some money to play with.
paradigm shift is offline
Old 02-07-2006 | 08:49 PM
Elite Marine's Avatar
I spoke at length with ASM. The software they created is based on Merc software, however it works only with the ASM ECU, which is MEFI 4. An adapter for the MEFI 3 to MEFI 4 conversion is available. The different packages offered allow a user to use the software on an ECU previous mapped by ASM or purchase a new ECU and the software together. It is actually a pretty good price if you compare it to Holley and others with programmable software out there.
The only issue is that is this worth it for a one time mapping of an ECU. Once they're set, they don't require tweaking, so a couple thousand dollars may be wasted compared to having your ECU mapped on a dyno for $ 300.00 - 500.00 + dyno cost.
Elite Marine is offline
Old 02-07-2006 | 09:29 PM
Ray @ Raylar
that i find HARD to believe......
rvrholic is offline
Old 02-08-2006 | 09:26 AM
Ray @ Raylar
Didn't you guys claim you could use the merc ecu without needing to change any mapping, or maybe you still do.
Cam-shaft is offline
Old 02-08-2006 | 09:51 AM
JasonSmith's Avatar
If ASM only letts you do one ECU, what a waste. I'll look at the software from the mfg that Ray was talking about.
