HP500 EFI Closed Cooling and HP525 EFI Serial #
Hi All,
I haven't been able to find a closed cooling upgrade kit for the HP500 EFI from Mercruiser. One idea I had was that the HP525 EFI and HP500EFI are both very similar in exterior looks. I'm guessing that it might be possible to buy a set of parts that fit the HP525 and use them to install closed cooling system on the HP500.
Would someone with HP525 EFI engines be willing to send me a serial # from one of their engines? I can use the # to order a service manual and parts list for the HP525 and start researching whether this might be possible.
If you know of a closed cooling upgrade kit part # for the HP500 EFI, that would be even better.
Thanks,
Garrett
Thanks,
Garrett
Originally Posted by FormulaM2Formula
Hi All,
Thanks,
Garrett
Thanks,
Garrett
There are aftermarket kits for this that have been talked about on OSO. I wold post this in the General Discusion area.
Jon
Jon
Put your best foot forward!
Originally Posted by offthefront
Garrett .. i was looking at some just the other nite that were nice ... I'll try to remember and post the site .m
Garrett
Innovation Marine in Sarasota FL, does a great job with closed cooling on their setups. They have rebuilt some 500efis that I have seen with closed cooling, and it looks amazing. I'll email you their number tomorrow.
Corey
Corey
Corey
Corey
I left them my number. They said they would give me a call back and let me know what they come up with. I'll keep you all posted.
Garrett
FYI
The HP500 and HP500efi use cast iron heads, while the HP525 uses a aluminum head with water ports on the faces of the heads where the heat exchanger is plumbed too. Now I'm going off memory(of 525's i've seen), but I'm 99% sure this is how there setup. So a HP525 setup wouldn't work anyways.
LE
LE
Michael1
Drives and Lower Units
1
10-25-2007 05:35 AM
zimm17
0
03-24-2007 05:48 PM
