Information on 525sc's, carbarated. >
Old 02-23-2006 | 10:17 AM
Default Information on 525sc's, carbarated.
Wanted to know about reliability, how many hours they are good for and any other issues, any help would be appreciated. Thanks, Larry
427 larry is offline
Old 02-23-2006 | 10:30 AM
JS232's Avatar
Default Re: Information on 525sc's, carbarated.
A friend runs one in his 29 Scarab, no probs but He really babyed it . He's got around 300 hrs on it, Only issue was with the blower, oil was spilling in the bilge area. Eared they generally need a rebuilt(Blower) around 250-300 hrs, other than that, looks like a really strong engine.
JS232 is offline
Old 02-23-2006 | 10:42 AM
DRIPPINWETII's Avatar
Great engines,turn key. Like JS232 said, blower rebuild around 300hrs otherwise bullet proof. My blowers leeked a little oil from the fill screws. I was told by B&M,now Holley,to replace original screws that have pin hole with one that doesn't have hole.
Attached Thumbnails Information on 525sc's, carbarated.-cleland-engines-001.jpg   Information on 525sc's, carbarated.-cleland-engines-002.jpg
DRIPPINWETII is offline
Old 02-23-2006 | 10:51 AM
JS232's Avatar
How fast does you 30' run with that huge power?
JS232 is offline
Old 02-23-2006 | 10:58 AM
I am right at 90mph now. I am running 34 bravos with 1.65 gears. I am still up on the rev limiters. In the process of changing gears to 1.50 and adding nose cones. Hopefully will be able to run same prop when labbed.
Old 02-23-2006 | 11:03 AM
JS232's Avatar
Interesting numbers!
Your boat seemed to handle the big stuff pretty well on the last milk run...
JS232 is offline
Old 02-23-2006 | 11:11 AM
Not well enough! I thought my windshield was going to break a few times. The last leg we couldn't keep the props in the water. We put the Bravo's to the test that day. Bigger tabs may be my next purchase.
Old 02-23-2006 | 12:39 PM
Do a search for 525SC. Lots of info has been discussed about them.
Its been a great engine for me. Very reliable and turn key.
Griff is offline
Old 02-26-2006 | 05:05 PM
Hi Everyone, Thanks for all the help and info., I also did a search on 525SC and learned a lot, will let you know what happens on this boat I am looking at.
Old 02-26-2006 | 06:28 PM
mboger's Avatar
larry what are you doing repower or a new boat
mboger is offline
