Prop shaft adaptors
A bravo 3 outer shaft isn't splined on the inside. Every Bravo/Trs/ Alpha that I have with a twisted prop shaft is in the spline area. Usually in the middle of the splines. Very rare on alpha it usually blows the pinion gear first. I would think that putting this between the prop and shaft also using the XZ solid Flotorque adapter would substantialy reinforce the shaft. Unless there is a fully splined adapter or prop hub that would fully distribute the load on the propshaft. Just my 2cts. BBB
MIKEHTMSR24
07-22-2002 03:18 PM
