CMI E-Top Lites with Silent Choice
I heard E-Top Lites, which just have a flange for a standard 4" rubber exhaust hose will work with Silent choice. I suppose you just connect the two with a short piece of 4" exhaust hose. Has anyone tried this, does it really work?
im not certain but i thought the E tops have a steeper angle on the down tube and need an E-top specific exhaust diverter to meet the Y pipe correctly
08 OPA High Points Champion
Contact Randy Leider @ CMI to verify.
Originally Posted by Panther
Is it me or do the Lites have a longer runner length than the e-tops?
Frank the both have 16" runners. They look longer on the Lites because the center two runners are on the the outside. On the standard E-Top they're tucked in behind.
Also the standard question, would I need to reprogram the EFI? Fred says no, HotBoat Mag says yes???
In the picture they do look taller and steeper than my stockers. Might fit with lots of tweaking the silent choice and hoses. Tip it steeper, longer hose to the yPipe, etc.
teaguecustommarine
New Products and Member Discounts
0
08-09-2006 12:25 PM
