WoW, Inflatable PFD....Something you should know
I do not know if this applies to all inflatable PFD's but I thought it was worth bringing to everyones attention that unless you are wearing it the PFD DOES NOT count towards the number you may need on board.
I learned something new today.
"USCG Type Type V with Type III performance: This vest must be worn to be counted in vessel's inventory of PFDs"
http://www.westmarine.com/webapp/wcs...oductId=221657
Cordell
Cordell
I would leave those things on your fishing boat. I see Poker Runners wearing those and I cringe. They are not designed for high speed impacts.
Those inflatables are designed for having a boat sink under your feet while at a dead stop. Don't expect those to do ANYTHING for you if you get tossed out at 40 mph or higher.
08 OPA High Points Champion
any person that ride in an open boat must wear a pfd that have visible color (orange for ex.) have to be solid for various reasons, more buoyancy, turn you over,absorb impact (in case you get ejected), for those runnings in close canopy you have to wear an inflatable, why? in case you are upside down you will have negative buoyancy and can exit your boat. RF(Offshore Rescue,Service & Supplies)
Brad the canopy vests dont inflate automatically and i dont think the hatch is manditory. mine fit very snugly and have a mesh type material that keep the whole thing tight. its similar to the one pictured above but built for racing. the air bags are tucked into the vest and held in velcro pockets there is a rip cord at the bottom to inflate. i will take some pics. i have four on the boat for myself and passangers.
I am not sure I understand that logic of the canopy boat. If the canopy fills with water the inflatable will inflate and you would have the same negative buoyancy. Many times they do not fill with water right away. Most canopy boats are required to have escape hatches in the floor for racing. Upside down and you go up to the scape hatch. I also think offshore racers use lifeline canopy style jackets which look thinner and fit through the legs. I would like to understand this as I have a new full canopy boat with seat belts along with an escape hatch and I am about to order 6 jackets for Poker Runs.
Surgin' General
06-22-2005 09:19 AM
