do you need to change jets with a 1" hvh spacer? >
Old 03-02-2006 | 01:53 PM
BajaRunner's Avatar
Default do you need to change jets with a 1" hvh spacer?
Just curious if it throws it off enough that you need to change jets with a 1" hvh spacer.
BajaRunner is offline
Old 03-02-2006 | 02:21 PM
Default Re: do you need to change jets with a 1" hvh spacer?
I doubt it especially on stock 500HP's. The jetting is on the rich side to start with.
Griff is offline
Old 03-02-2006 | 02:29 PM
PatriYacht's Avatar
According to the guys at HVH you generally have to go down a size or two. The Super Sucker smoothes the flow of air and increases the signal to the carb.
PatriYacht is offline
Old 03-02-2006 | 03:13 PM
Since the HVH design increases the air velocity, it should pull more fuel. If the engine was tuned properly before you should be richer with the HVH Spacer, so you may need to go down a jets size or two.
RumRunner is offline
Old 03-02-2006 | 06:23 PM
axapowell's Avatar
Where To
I had to jet down a few sizes after I installed mine, but these were put on FRESH motors with better heads.
Dave
axapowell is offline
littledcsrodshop
Swap Shop
1
08-30-2008 12:36 PM
BajaRunner
31
04-27-2006 01:17 PM
BajaRunner
9
01-29-2006 06:40 AM
BajaRunner
21
12-29-2005 04:05 PM
Scott
7
01-02-2003 10:05 AM
