Hitch upgrade
Old 03-02-2006 | 09:29 PM
WAGS382's Avatar
Default Hitch upgrade
I just ordered a putnam XDR hitch for my 06 2500 HD chevy.
I am looking for advice on the mount for the trailer light connection.
I want a clean look like the factory set-up not some back yard after thought.
Any advice would be appreciated.
Jeff
WAGS382 is offline
Old 03-02-2006 | 09:35 PM
hunster's Avatar
Default Re: Hitch upgrade
www.trailerwiring.com
hunster is offline
Old 03-02-2006 | 10:11 PM
Poorsche's Avatar
Check out http://www.jetconnex.com/ They've got the connectors and the coiled connector wire. Boaters World and West sell them but best way to putrchase is on-line. The stores only have limited choices of setup combo's.
Poorsche is offline
Old 03-02-2006 | 10:27 PM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
I'll will try to get some info for you tomorrow off of www.chevyavalanchefanclub.com . I opted to use my same factory connector, and drilled it into the factory Avalanche bumper (with cladding) to the left of the license plate. It works well, but no room for error when you have a steel bumper. Several folks who have moved theirs to the bumper are using a new piece that has the round connector as well as a 4-pin flat connector. It looks very proper on the bumper.
Sydwayz is offline
Old 03-02-2006 | 11:22 PM
Outdrive1's Avatar
Masher touches my
Cut a hole in your bumper and mount it there. I did it in my Tahoe and it looked factory when I was done.
Outdrive1 is offline
Old 03-03-2006 | 08:02 AM
Sydwayz's Avatar
Forum Regulator
Veteran: Air Force
http://www.chevyavalanchefanclub.com...c,29387.0.html
Hoppy part number: 40955
Attached Thumbnails Hitch upgrade-500holedone1.jpg   Hitch upgrade-500complete.jpg   Hitch upgrade-500closeup.jpg
Sydwayz is offline
Old 03-06-2006 | 08:03 AM
RedDog382's Avatar
Jeff,
Here is how I would upgrade your hitch ...
RedDog382 is offline
Old 03-06-2006 | 06:19 PM
WAGS382's Avatar
Originally Posted by RedDog382
Jeff,
That hurt
Chris
You should put some ford motors in you boat .
To everone else
Thanks for the input, I like the look of the bumper set-up.
Jeff
WAGS382 is offline
Old 03-06-2006 | 06:53 PM
RedDog382's Avatar
Just messin' with ya Jeff!
BeakBoater35
8
08-15-2008 11:03 AM
BillR
2
10-24-2007 08:36 AM
Chris288
14
06-22-2007 05:05 PM
aquatictherapy
1
04-06-2006 01:03 PM
Boomer35
13
11-11-2005 07:04 PM
