Can a 572ci make 850hp na? under 6000rpm >
Old 03-04-2006 | 12:30 AM
Default Can a 572ci make 850hp na? under 6000rpm
guru's of oso I need your help ...
can this be done and have the motors live?
making upper 700's now..you know how it is their is never enough under the hatch
Shawn
soinc is offline
Old 03-04-2006 | 01:24 AM
woody1's Avatar
Default Re: Can a 572ci make 850hp na? under 6000rpm
Shawn
Im not sure of the chevy's efficiency but we can make that with the 557 inch Fords, fairly easily, 6200rpm. It's a little over 1.5 hp per inch
woody1 is offline
Old 03-04-2006 | 01:43 AM
ratman's Avatar
steve schmidt has a 925 pump gas na motor i think is a 572 short block. 800+ ft lbs of tq, for 25k ea, sweet looking mills
ratman is offline
Old 03-04-2006 | 09:27 AM
PatriYacht's Avatar
Doubt it. It would take more r's and unboatlike things like very high compression. Put 4-5 lbs of boost on it and make more hp with less wear and tear.
PatriYacht is offline
Old 03-04-2006 | 09:53 AM
Brad Zastrow's Avatar
I do not think you will get to 850 on 93 octane. Race gas you can. It will take too much compression. I have been told about 750 is it with 572 CI N/A without spending big bucks for the exotic stuff. Horsepower costs money. The saying goes: "Speed cost money, how much do you want to spend?"
Brad Zastrow is offline
Old 03-04-2006 | 10:11 AM
whats a Ford????
pullmytrigger is offline
Old 03-04-2006 | 10:34 AM
ratman's Avatar
wrong! TWIN 585 MARINE SSCE POWER, 980 HORSEPOWER & 825 FT.LBS. OF TORQUE,
• Runs on Regular Gasoline
• 10" of Manifold Vacuum
• Great Idle
• Terrific Throttle Response
• Built To Run 100's of Hours Before Maintance 26,950ea
heres the link to thier site
ratman is offline
Old 03-04-2006 | 10:37 AM
ratman's Avatar
its a 585 ci eng, probably 4.625 stroke vs 4.50 for a 572. if i had know about these bad azz na engines i would probably have a pair of these in my cig now! beatiful engines, and these guys make 1000+ hp with single centrifical blower with single 850 cfm carb on a 572!!!
ratman is offline
Old 03-04-2006 | 10:39 AM
last year I made 820hp @ 5700 with this combo on pump gas. 4.375 stroke, 4.6 bore, 582", static cr 10.5, dart heads, crane hyd roller, eldelbrock victor with a BLP carb. in the boat you need a very good set of headers to see the hp, run cold h2o temps and keep a good tune, ran 130 hrs last year. This year I am rasing the static to 11 to 1 and sent the intake to keith wilson for blue printing. I am hoping for 850 to 875hp. gg
gg10 is offline
Old 03-04-2006 | 10:40 AM
ratman's Avatar
btw im sure you could get them to build a little smaller eng like a 572 and make 850 hp, but i would stay with a proven combo like the 585 set up, good luck. let us know if you get a pair! peace out, rm
ratman is offline
