Baltek ContourKore
Old 03-06-2006 | 06:25 PM
KNOT-RIGHT's Avatar
Default Baltek ContourKore
Any one ever use Baltek contourkore its in the defender
catalog ?I want to use it for the birth support. (bed)
I was thinking 3/4 inch thick with a span of 48 inches.
Do you think it will support the load.
My plan is to install two sheets side by side. Starting on the
tunnel and going to the far starboard gunnel in the (starboard)
sponson. (46 skater) The bed will run with wise.
It will be 6 feet by 4 feet wide.
The access to the cabin on this Skater is on the port side
sponson. So when you enter look to your right the bed will be
there.
Any thoughts?
Gerry
KNOT-RIGHT is offline
Old 03-07-2006 | 11:29 PM
FX10's Avatar
Default Re: Baltek ContourKore
3/4 " should be fine for what youm want to do. Ever look into Divinycell ?? Alot lighter. We use it on our decks and hull siddes. Strong ****.
Rick
FX10 is offline
Old 03-12-2006 | 07:52 AM
KNOT-RIGHT's Avatar
Rick
Who has this stuff?
Old 03-12-2006 | 01:38 PM
KNOT-RIGHT's Avatar
Well the Baltek arrived friday. It is nice stuff howver
it is not rigid. It would be great to sandwich between
glass. It is a coring product.
I will call composite 1 and see what they have.
Old 03-14-2006 | 06:34 AM
PatriYacht's Avatar
Baltek makes flat panels with end grain balsa sandwiched between layers of fiberglass. They are about as stong as an equivalent thickness of plywood but much lighter. They call it Decolite.
PatriYacht is offline
Old 03-14-2006 | 09:11 PM
KNOT-RIGHT's Avatar
Where can I get this stuff?
Gerry
Old 03-15-2006 | 07:19 PM
FX10's Avatar
I'll make a few cals tomorrow. Baltec also sell the foam coring under the name Air-lite.
FX10 is offline
Old 03-15-2006 | 07:36 PM
KNOT-RIGHT's Avatar
There is a company here in Bristol RI called
Composites 1. they have a 4x8 sheet pannel that would work
its $300 if it comes down to it I will grab it.
which stuff on here would work?http://www.baltek.com/products/decolite/decolite.html
Thanks in advance
Gerry
Old 03-15-2006 | 09:56 PM
Coolerman's Avatar
PF Marine
That stuff is great. We used it on our hatches. Lightweight and extremely strong!
Coolerman is offline
Old 03-16-2006 | 08:01 PM
Gerry, Do you have the phone and address of "Composits 1"? I want to build some boxes about 20" x 20" x 14' for the underside of my box truck.I priced out aluminum custom made boxes and even thou this stuff is $300 per sheet I think I would be better off. Thanks AW
obads 31 is offline
