After Katrina, is MPI any good !! >
Old 03-10-2006 | 09:41 AM
Default After Katrina, is MPI any good !!
Had 19 feet of water where I live. Garage flooded to the ceiling.
In that garage, I had two 502 MPI's with the VST, intakes, rails, computers, wires, etc. (not connected to a battery)
Cleaned everything with a garden hose. Is any of it any good?
Thanks, Jim Rose, Biloxi, MS
jerosejr is offline
Old 03-10-2006 | 12:00 PM
Default Re: After Katrina, is MPI any good !!
well... maybe... but unlikely if they have sat this long w/ out attention.
at the very least you need to see if they stiil turn... if not then they are cores for rebuild... if yes then MAYBE but all really depends on how long they have sat full of water . the electronics are likely scrap.
stevesxm is offline
Old 03-10-2006 | 01:20 PM
Brad Zastrow's Avatar
I would assume the worst on the engine and the electronics. All junk. I would bet there is still water in the engine. Everything will be pitted and rusted.
Brad Zastrow is offline
Old 03-10-2006 | 02:14 PM
Smitty's Avatar
All of the wiring will be junk soon if it is not already. Once water gets in, it only a matter of time till it won't flow current any more. The electronic boxes should be water tight except for the connectors. If the motors weren't dissasembled right away , then everything inside will be all rusted and basically junk too.
Sorry
Smitty
Smitty is offline
Old 03-10-2006 | 05:02 PM
Sorry about the confusion guys. I only had the EFI stuff in the garage (intake, computer, wires, VST, fuel rail, etc).
jerosejr is offline
Old 03-10-2006 | 08:46 PM
Smitty's Avatar
Well then I guess I would say only the wire harness should be replaced to 100% safe.
Smitty is offline
01hammer
10
06-24-2008 11:32 PM
CigDaze
08-29-2005 07:14 AM
kraftaroni
4
07-19-2005 10:14 AM
pantera38
1
02-02-2003 04:44 PM
