trailer modification
Old 03-10-2006 | 05:42 PM
flatout's Avatar
Default trailer modification
Anyone extened the tounge on a trailer before? I was told and had the idea myself that you could cut the the tounge slide a piece of matching square tubing on both cut ends and weld. this would be for a short 2.5 foot extension. I had even thought of putting a major bolt through both sides as security in case the weld failed. any thoughts?
flatout is offline
Old 03-10-2006 | 06:36 PM
'05 Concept SF23
Default Re: trailer modification
Ought to work with stffner tube inside the origanal tube.
f311fr1 is offline
Old 03-10-2006 | 07:14 PM
jeff32's Avatar
I think there is no problem at all! beside the lenght of you brake line, electrical wire...But why would you do this?
jeff32 is offline
Old 03-12-2006 | 12:00 AM
wwwTOPDJcom's Avatar
must have bought a 27' fountain and needs to fit it on a 25ft trailer
wwwTOPDJcom is offline
Old 03-12-2006 | 08:47 AM
ChrisK's Avatar
Moderator
if it was a 27' fountain no mods would be nessisary on a 25' trailer..
ChrisK is offline
Old 03-12-2006 | 08:58 AM
US1 Fountain's Avatar
Ginger or Mary Ann?
<US1 is rolling up his sleeves>
US1 Fountain is offline
Old 03-23-2006 | 08:14 PM
flatout's Avatar
Thanks for the info guys, I ended up ging to the manufacturer they already had a longer tongue I just have to bolt it on. I had to do it because I bought a boat and trailer seperate. The trailer is rated for 24-26 boat and the boat is a 27. I thought i could get away with extending the bunks and letting it hang over the end but that created balance issues. So I am lengthening the front instead.
flatout is offline
Old 03-23-2006 | 11:32 PM
Ginger or Mary Ann?
Did you recheck your tongue wieght after the modification?
Old 03-24-2006 | 04:18 PM
flatout's Avatar
I haven't finished the mod yet. I spoke to the manufacturer, actually a mechanic that builds and services them he told me all the changes I had to do. The axles are adjustable and he told me where to put them. He told me the tongue weight would be about 500 lbs.
flatout is offline
nickodemo
0
11-29-2006 03:31 PM
FX10
Superboat
10
12-11-2004 12:56 PM
Manils
0
09-10-2004 12:15 AM
HyperBaja
Baja
4
10-14-2002 01:48 PM
