where to put depth sender >
Old 03-15-2006 | 11:18 AM
sleeper_dave's Avatar
Default where to put depth sender
I redid my dash this year, and bought a new depthsounder for it. The old one didn't work at any speed anymore, it was mounted on the transom.
The new one has a through-hull transducer.
Where is the best place to mount it?
sleeper_dave is offline
Old 03-15-2006 | 11:54 AM
DollaBill's Avatar
OSO OG
Default Re: where to put depth sender
good luck if it is stepped.
DollaBill is offline
Old 03-15-2006 | 12:20 PM
itilldo's Avatar
Mine is in the access hole under the cabin step area. 04 29'
itilldo is offline
Old 03-15-2006 | 12:37 PM
Rebel_Heart's Avatar
I spent the $ to put one in a couple of years ago, and it never has worked. I don't think that it is getting a reading at all. Wish I hadn't wasted the money.
Rebel_Heart is offline
Old 03-15-2006 | 03:11 PM
Downtown42's Avatar
They wont work thru the hull unless you drill hole to mount flush to underneath hull. I'd pass on it as well. My 35 never worked.
Downtown42 is offline
Old 03-15-2006 | 03:38 PM
US1 Fountain's Avatar
Ginger or Mary Ann?
Ditto! It takes up valueable dash space
US1 Fountain is offline
Old 03-15-2006 | 10:29 PM
my boat is a '91. no step.
is there coring in the bottom?
the boat's at the fiberglass shop right now. it's either a matter of paying him to make it work through the hull, or ordering an external transducer and having him install it.
i boat in shallow water all the time, and i'm getting kind of sick of using my GPS as a depthfinder
Old 03-16-2006 | 06:56 AM
Mount it at least 10" off of the keel (center of vee), there is coring from the keel out 10". With no step, you should be ok mounting just about anywhere from the cabin step down back.
rackster is offline
Old 03-16-2006 | 11:04 AM
search this forum......theres a few threads on it.......I used the plastic bag/water method through the hull on my 29 non step......works fine when your off plane........doug
pullmytrigger is offline
Old 03-16-2006 | 11:26 AM
GOODT's Avatar
Have mounted many here when was working for the dealer with no problems, just make sure you sand both surfaces and use a good two part epoxy !!!!!!
GOODT is offline
