What To Expect
Old 03-16-2006 | 02:52 PM
BY U BOY's Avatar
Default What To Expect
What Can I Expect To See? Adding 750 Holly And Msd This Weekend. 454/b1 330. Also I Will Test This With 23p Mirage. Then With A 25p Mirage Plus That I Will Cut Down To A 24p.
Sent My Money For Whipple Off Today I Think I May Have Addressed The Envelope Wrong It Went To The Irs.
BY U BOY is offline
Old 03-16-2006 | 07:21 PM
Payton's Avatar
Charter Member #927
Default Re: What To Expect
about 335hp, maybe 350 if you change the exhaust. Sorry.
Payton is offline
Old 03-16-2006 | 08:00 PM
cuda's Avatar
I'd be interested in the results. I'm changing to a TBIV ignition, and a Performer intake. I'll do the distributor change this weekend. Still trying to decide on exhaust. I have a clearance issue on the exhaust.
cuda is offline
Old 03-17-2006 | 09:23 AM
BY U BOY's Avatar
NO APOLOGY NEEDED I KNEW IT WOULD NOT BE MUCH. JUST WANTED TO GET AN IDEA ON SOME NUMBERS. I WILL BE ADDING NEW HEADS AND EXSAUST BY THE END OF THE MONTH ALONG WITH A LARGER CAM TRYING TO GET TO 425HP
CUDA ILL LET YOU KNOW IF ANY INCREASE IN POWER.
BY U BOY is offline
Old 03-17-2006 | 09:53 AM
Payton's Avatar
Charter Member #927
That sounds better.
Payton is offline
Old 03-17-2006 | 10:01 AM
PatriYacht's Avatar
If you're changing from a points dist. to an MSD, you may see quite a difference. I picked up 200 rpm's when I did it a few boats ago.
PatriYacht is offline
FRMULTR
Prop Talk
15
09-15-2008 07:30 AM
BY U BOY
Hustler
10
04-12-2008 11:30 AM
BY U BOY
04-09-2008 10:26 PM
CAPTAIN CHUCK
08-07-2007 08:15 AM
