Locking Header Bolts... >
Old 03-16-2006 | 07:40 PM
Default Locking Header Bolts...
Just ordered some Breslin Split-lock Stainless header bolts that CMI sells through Trick Marine.
I had a tuff time keeping the standard steel ones from loosining up all the time.
Do they really work well?...at $65 per set of (16) I would hope so.
Is there anything to look out when using them on Aluminum heads?
Back4More is offline
Old 03-16-2006 | 07:55 PM
Vinny P's Avatar
I hate the winter!!
Default Re: Locking Header Bolts...
Thats strange. While I checked them often, my bolts stayed tight all season on my CMI's and AFR heads. I hope they solve your problem.
Vinny P is offline
Old 03-16-2006 | 08:36 PM
Too Old's Avatar
The reports I get back from customers is that they work great.
Too Old is offline
Old 03-16-2006 | 09:35 PM
paradigm shift's Avatar
I have had no problem. I do have to tighten them up after install of new gaskets a couple times. Once they get heat cycled a few times. Not all aluminumm heads have inserts in threaded holes so watch for pulling the threads out on aluminum.
paradigm shift is offline
Old 03-18-2006 | 03:21 PM
I switched to SS ARP studs instead of bolts and haven't had one come loose in 65+ hrs.
Griff is offline
Old 03-19-2006 | 11:18 AM
monstaaa's Avatar
those do work, just dont forget to looesen the set screw when you service the exhaust.
i found that using s.s bolts with the thick posiloc washers and coper reusable gaskets is the way to go. no more blown header gaskets or loose bolts.
monstaaa is offline
Old 03-19-2006 | 11:26 AM
Strip Poker 388's Avatar
Rob
I have the SS ARP's also . On new gaskets and a few heat cycles retighten them .they dont loosen up any more sfter that.The first time I tore it down the had 185 hours on them.
Rob
Strip Poker 388 is offline
BadDog
1
03-03-2006 11:23 PM
Downtown42
5
05-31-2005 03:44 PM
RutRow
2
08-19-2004 09:03 AM
klaw
1
08-10-2004 12:39 PM
