Donzi Black Widow
Old 03-18-2006 | 03:27 PM
Default Donzi Black Widow
This might sound stupid...will a very slightly bent propeller shaft, with no vibration, cause you to not be able to get out of the hole and almost freeze at 3500 rpm untill it gets on plane?? It's a 454 with a King Cobra outdrive.
Man do I need help!
bob896 is offline
Old 03-18-2006 | 03:43 PM
Default Re: Donzi Black Widow
I ran around fora month and a half with a slightly bent propshaft.......only found it when I changed gear oil and found milk........I had filed a small ding out of the one prop.......Iwas down a little bit in top speed.....maybe 1 to 1.5 mph.....everything else fine
pullmytrigger is offline
Old 03-18-2006 | 03:55 PM
There is no milk, new carb only ran a couple times. Is it worth changing the shaft?
bob896 is offline
Old 03-18-2006 | 05:11 PM
Too Old's Avatar
Man do I need help!
I don't think so. Have you had the boat long???
Too Old is offline
Old 03-19-2006 | 06:17 AM
Payton's Avatar
Charter Member #927
I ran my boat with a bent prop shaft for half a season before I changed it. I saw difference either way.
I would take a closer look at the new carb, or linkage.
Payton is offline
Lofty
Donzi
14
01-04-2009 04:37 PM
jackhammer
Donzi
9
07-05-2004 04:29 PM
fobes
11-17-2003 04:43 AM
boot
03-14-2002 12:22 PM
