233 hull blueprint
I'm trying to blueprint the hull on my '78 233 formula. I have found it has rocker, how much flat hull should it have ahead of the transom to run safe, with a max speed of 65-70mph.
Any input would be appreciated, thanks.
You can also get a 4' aluminum straight edge from Sears for approx $7 bucks. If you need 8' you could attached two of them at the ends. It would be just short of 8' and make sure you align them properly before securing.
Fast Shafts
12-13-2007 01:33 PM
