Bravo One compared to Chopper II
HI!
The Bravo One 4 blade prop is lower in pitch than stamped. How does a Chopper II 3 blade 28 compare in pitch to a Bravo One 4 blade prop? If the Bravo One is lower in pitch than the 28 stamped, how does it compare to a 3 blade. Normally a 4 blade compensate for pitch.
Cheeeers, Toffen G
Cheeeers, Toffen G
Do you mean how do they compare in pitch or how do they compare in general?
They are completely different in geometry and characteristics if that is that is what you are asking.
As far as pitch, the chopper is higher but yes the extra blade and hub can equalize the rpm outcome.
[email protected]
[email protected]
Hi!
Thanks. It was the pitch comparison I ws after.
But how will you compare the caracteristics between the Bravo One 4 blade and the Tempest 3 blade?
Cheeeers, Toffen G
Cheeeers, Toffen G
tomas_wallin
Drives and Lower Units
2
10-17-2007 07:57 PM
tomas_wallin
7
01-12-2006 01:28 PM
