Summer? The Ice is Off The Test Tank...Almost >
Old 03-30-2006 | 07:04 AM
Double R Performance's Avatar
NorTechNorth.com
Default Summer? The Ice is Off The Test Tank...Almost
Well, the lake is still a write-off. The tank was clear enough yesterday to get a boat in though. Have faith, summer will come.
Double R Performance is offline
Old 03-30-2006 | 07:08 AM
NorTechNorth.com
Default Re: Summer? The Ice is Off The Test Tank...Almost
Photos
Attached Thumbnails Summer? The Ice is Off The Test Tank...Almost-p1010358.jpg   Summer? The Ice is Off The Test Tank...Almost-p1010353.jpg
Old 03-30-2006 | 07:25 AM
I need a set up like that in my back yard!!!!!
Pure Energy is offline
Old 03-30-2006 | 08:53 AM
Is that test tank lined like a swimming pool? And do you have any filtration or water circulation? Just inquiring.
rsess is offline
Old 03-30-2006 | 09:06 AM
NorTechNorth.com
No liner.
Big time filtration system. We have to keep the water clean and the pH levels good.
We have 12 tubes (six on each side of the back wall), each 12 inces in diameter, to circulate the water around to the front when we have big power floating at the back of the tank. Otherwise, we'd blow out the wall, even with cut down props.
-Peter
Old 03-30-2006 | 10:07 AM
Bobthebuilder's Avatar
Hello Peter,
Just about to go out the door for Sarasota and saw your thread. Tell me - when will the ice be off the Bay ?? Not that I am in any hurry to get back up there. 85 deg and nothing but sunshine here today. Gulf is dead flat calm and weather is to hold for the weekend.
Hoping to hear from Raymond later to day on our "little project" and look forward to having him on the boat Sat. Next time he should stay home and mind the store while you get away. Oh, I forgot - he's "working" LOL Later.
Bob
Bobthebuilder is offline
Old 03-30-2006 | 11:57 AM
That is a great idea to test motors. I have never seen that before.
BobbyB is offline
Old 03-30-2006 | 12:01 PM
GLH's Avatar
GLH
Isn't climbing in the back of the pick up a concern? How much HP/Prop Pitch and RPM have you had that tank worked at?
Very interesting set up.. Good Idea.
GLH is offline
Old 03-30-2006 | 01:37 PM
Airpacker's Avatar
GL, its a sweet set up. Essentially 0 pitch water beaters are installed for props. BIG anchors are installed in the concrete to tie the boat to as well.
Airpacker is offline
Old 03-30-2006 | 01:41 PM
BLee's Avatar
Charter Mod
That can eliminate problems BEFORE you get to the ramp or out in the middle of the water. Sweet.
BLee is offline
