Depth Sounder type????
Old 03-30-2006 | 11:27 AM
Default Depth Sounder type????
Looks like my boat was prefit with a depth sounder, the transducer is mounted to the bottom and the wire goes to the dash but it was never finished. There is no gauge, just the wire bundled up under the dash. Does anyone know what brand unit I need to attach to this transducer. The transducer is black with no markings on it at all, neither does the wire. The connector is a two prong, male square end with a square hole in one side that plugs into some head unit. Thanks for any ideas.
Attached Thumbnails Depth Sounder type????-sounder1.jpg   Depth Sounder type????-sounder3.jpg   Depth Sounder type????-sounder5.jpg
Pismo10 is offline
Old 03-30-2006 | 11:28 AM
Default Re: Depth Sounder type????
More pix.
Attached Thumbnails Depth Sounder type????-sounder2.jpg   Depth Sounder type????-sounder4.jpg
Pismo10 is offline
Old 03-30-2006 | 11:48 AM
Dave M's Avatar
Veteran: Navy
I'm not sure what type that is. Man, you really need to clean your bilge!
Dave M is offline
Old 03-30-2006 | 12:22 PM
Yes its still in storage up here in the great white north.
Pismo10 is offline
Old 03-30-2006 | 04:19 PM
No, I have no head unit of any type. What I am trying to figure is what brand depth gauge/unit I have to buy that will be compatible with this transducer.
Pismo10 is offline
Old 03-30-2006 | 04:32 PM
Pantera1's Avatar
I would grab a west marine catalog ..
Pantera1 is offline
Old 03-30-2006 | 05:15 PM
Prater's Avatar
Looks like the plug my Eagle sounder uses. Tht is a wild guess and generally the head unit will come with a new sounder anyways...
Prater is offline
Old 03-30-2006 | 08:10 PM
DollaBill's Avatar
OSO OG
if it appears to be more than a year or two old just but a new package. They aren't expensive.
DollaBill is offline
Old 03-31-2006 | 06:03 AM
IRONMAN's Avatar
Call this guy he has 'em all at good prices and can probably ID yours. Cheers.
http://www.brokenlegdave.com/welcome.htm
IRONMAN is offline
Old 03-31-2006 | 07:06 AM
Not to contradict Warbird, but those transducers are NOT universal. They operate at different frequencies and must match the dash unit or the readings will be useless or non-existent. If the unit is more than a year old just buy a new unit with the tranducer that comes with it. Follow the epoxy instructions to the letter and you will have a nice operating, accurate set-up. Good Luck.
Edward R. Cozzi is offline
