Won't start? >
Won't start?
Won't start?
Old 04-01-2006 | 05:51 PM
99fever27's Avatar
Default Won't start?
Went to put the boat in the water today. Turned the key engine cranks but no start. Not even a sputter. Hp500 with 80hrs, ran great 4months ago just before I took it in for winterizing. Checked for loose wires, fuses breakers etc and couldnt find anything out of place. Im sure im just missing something the mechanic did just before storage..any ideas?
99fever27 is offline
Old 04-01-2006 | 05:56 PM
Default Re: Won't start?
is it getting gas...? maybe the coil wire was knocked off when they were winterizing..?
FIVEPTOHH is offline
Old 04-01-2006 | 06:35 PM
35 White Lightning's Avatar
Registered User
Check the dead man switch I did that by accident before it flipped and no spark its worth a shot
35 White Lightning is offline
Old 04-01-2006 | 07:26 PM
99fever27's Avatar
Checked the coil wire and played with the dead man switch but still wouldnt fire. I am wondering if its getting fuel..I couldnt smell any.(yes I did fill the tank) Whats the best way to tell if you have spark? keep in mind i'll be by myself. One thing that keeps coming to mind is I had the shop reverse the gear lever..im running a RH prop and boat was set up to run a LH. Maybe the lever isnt reading like its in neutral?
Old 04-01-2006 | 08:12 PM
louietherigger's Avatar
Racer
Shouldnt crank at all if it's the shifter. Maybe your gas line shut off valve is in the off position? Also is ther a posibility that your kill switch is defective. I would put a little gas in the carb if it fires fuel is your issue. Good luck hope you find the problem.
louietherigger is offline
Old 04-01-2006 | 08:17 PM
99fever27's Avatar
Louie where would the gas line shut off valve be located.
Old 04-01-2006 | 09:10 PM
tomtbone1993's Avatar
Originally Posted by 99fever27
in the front of the bilge on the bottom
tomtbone1993 is offline
Old 04-01-2006 | 10:36 PM
jryan26's Avatar
Change the plugs. Sometimes when they fog the cylinders, it fouls the plugs.
jryan26 is offline
Old 04-02-2006 | 05:05 AM
itilldo's Avatar
Ditto...happend to me the seconnd time out. Tried to start but no spark at the motor. Looked around and found that one fo the kids tripped the darn thing.. Well the kill switch works.
itilldo is offline
Old 04-02-2006 | 10:20 PM
99fever27's Avatar
It runs!!
primed the carb with some raw gas and fired right up!
Cant help but think im an idiot for not checking the fuel cut off valve...but it was already on. Thank You all for your help and support...pics to follow..
