SBC Cam Questions >
SBC Cam Questions
SBC Cam Questions
Old 04-03-2006 | 01:42 PM
Question SBC Cam Questions
I’m considering upgrading the cam in my 383 stroker engine, and I’m stuck between two cams. The current cam is a Comp XM-262-H #12-236-3. This is a flat tappet cam. The ones I’m looking at are both hydraulic roller cams by Comp. XR-276HR-10 #12-423-8, and XM-276HR-12 #12-418-8. These cams seem to be virtually identical with the exception of lobe separation angle My questions are: How different would either cam make the engine run?
What advantage/disadvantage would I see with either cam?, And Which cam would be less prone to reversion? Currently the engine has stock style cast iron heads with port work, 9.5:1 compression, a cast iron high rise intake manifold, and stock style center rise exhaust manifolds. In his book, Dennis Moore recommends the XR-276HR-10 cam. Any comments would be most welcome.
Camshaft Specification Table
Part Number 12-423-8
Engine 1955-1998 Chevrolet262ci-400ci8cyl.
Grind Number CS XR276HR-10
Description
Intake Exhaust
Valve Adjustment 0 0
Gross Valve Lift 0.502 0.51
Duration At 0.006 Tappet Lift 276 282
Valve Timing At 0.006
Open Close
Intake 32 64
Exhaust 75 27
These Specs Are For The Cam Installed At 106 Intake CL
Intake Exhaust
Duration At 0.05 224 230
Lobe Lift 0.335 0.34
Lobe Separation 110
Recommended Valve Springs 986-16
Part Number 12-418-8
Grind Number CS XM 276HR-12
Description
Intake Exhaust
Gross Valve Lift 0.503 0.51
Open Close
Intake 28 68
Exhaust 75 27
These Specs Are For The Cam Installed At 110 Intake CL
Intake Exhaust
Lobe Separation 112
Liberator21 is offline
Old 04-11-2006 | 12:24 PM
Default Re: SBC Cam Questions
No one has any input???
Old 04-11-2006 | 02:18 PM
I am running the XM270HR in my SBC 400. It has a nice lope to it and will idle at 750 rpm which is important with an Alpha 1 outdrive. I'm turning a 14 1/4 x 20 screw at 5400rpm which is good for 60 mph. This is in a 20 footer that weighs in over 4000lbs.
Olds Eddie is offline
Full Force
14
04-16-2007 07:37 PM
ohmthis
9
12-01-2006 07:43 AM
Full Force
0
04-26-2006 01:07 PM
Cap206
8
01-10-2006 01:41 AM
SLP
13
11-20-2002 02:21 PM
