Corrosion help - Mercathode system >
Old 04-08-2006 | 10:48 AM
LPBoater's Avatar
Question Corrosion help - Mercathode system
Have a 38 fountain with bravo drives and boat at lake cumberland. I leave the boat in the slip for a couple of weeks at a time. Over time, the original paint starting to flake off the drive where it mates up with the bell housing. Is there a quick check of the mercathode system to make sure electrolysis is not the culprit. Next to my slip is a 1968 steel hull cris craft - a huge piece of crap for sure. I suspect the steel boat next to me is not helping - any ideas on this??
Thanks in advance.
LP
LPBoater is offline
Old 04-08-2006 | 10:57 AM
formula31's Avatar
Default Re: Corrosion help - Mercathode system
You are probably right, the boat next to you could be the culprit. Do you have magnesium anodes on the drives? If not, you should. The standard ones are zinc (heavy) and do nothing in freash water. I heard they are now using aluminum ones on new drives but your really need the magnesium ones. Do you have shorepower plugged in? Have a ground isolator?
formula31 is offline
Old 04-08-2006 | 05:06 PM
LPBoater's Avatar
I have the standard merc anodes on the drives. I do not leave the shore power on. I think I should just sink the big turd next to me.
LPBoater is offline
Old 04-09-2006 | 09:28 AM
MOP
You may be able to get the Mag anodes from the place in the post below, I know they makes them for some apps.
http://www.donzi.net/forums/showthre...agnesium+anode
MOP is offline
Old 04-09-2006 | 12:03 PM
it isn't whether you leave the shorepower on, it is if you have the boat plugged in or not. has to do with the ground wire completing the circuit with the dock, or the boat next door. the test would be to have the voltage in the water tested with a corrosion meter.
JIMG is offline
Old 04-09-2006 | 05:18 PM
LPBoater's Avatar
Shore power is not plugged in either. My thought was to check current flow and make sure my boat isn't the cathode..
LPBoater is offline
Old 04-09-2006 | 05:54 PM
formula31's Avatar
I was docked between wooden and steel boats, old ones, flying grounds. The magnesium helped a ton but they were being eaten away monthly and they aint cheap. I finally moved to a new dock 100 ft away and it stopped completley. Do the magnesium anodes. They really help. I get 2 years out of them now.
Old 04-10-2006 | 02:54 AM
Reed Jensen's Avatar
I think you mean , make sure the boat isn't the "anode"... it is the anode that dissolves. Metal travels from the anode to the cathode.
Reed Jensen is offline
johnkot
1
05-27-2009 06:04 AM
johnny g
8
10-31-2008 03:43 PM
RUSSSR1
3
07-07-2005 07:07 AM
Dave M
9
11-03-2004 12:45 PM
Poorsche
14
06-17-2004 07:09 PM
